Fritz Maurer
A friend bought this late 80s C-60 as-is not running, Im trying to get it going for him. My two questions are, do we need this pressure regulator for a quadrajet which is fed with a mechanical pump? Someone went to a lot of trouble to do this, I have never seen a Q-jet set up this way. I expect it originally had a Holley governor carb, since the distributor is still in it. Second, the vacuum line to the right , coming from the brake booster, has a tee with a line going down to a PCV valve in the valve cover. Will it build boost this way? The booster also has hydraulic assist powered by the steering pump. Also, can someone ID this motor for us? Any input appreciated. Thanks, Fritz
