Need dexta parts
901sos
I finely split my (new to me,told it ran but wouldn't move) 59 dexta to locate the no drive to the wheels, what i found is the adaptor plate that bolts to the flywheel to mount the two stage live pto clutch is broken in half. My question is where can i get a new or used adaptor plate, part # is E82-GC-9 ; image#44 on page 86 of my factory parts book. Any help to locate it greatly appreciated,& email is open.
901sos,
I finally found a diagram of the part. Your email is not on so I don't know how to contact you other than replying in a post.
I need to know what size clutch disc your tractor uses. 9 inch or 11 inch. It looks like it basically uses the same double clutch aas in the super dexta and other fords such as the four cylinder ford 2000 and 4000. I don't know if it requires the adapter plate if using these assemblies.
It would also help to know the distance from the center of the mounting holes.
DeutzLover, i should have taken it apart further before posting but when the parts book said no longer serviced i got worried about finding
parts. After i posted i have taken the clutch off the adaptor plate & found the plate that is broke in half is the pressure plate that is
part of the clutch assembly & not the adaptor (good news!first time dealing with a two stage clutch for me never even driven one & have
owned 40+ tractors over the years.) So with a new clutch i should be in good shape. I will try to open email as if you have dexta & or major
parts there are a few other parts i am looking for, thankyou for tying to helpout.
I misread your last post. Yes, the two stage clutch assemblies are available in a number of places since they fit a number of Fords.
