kennytractor
I think after reading about the problems with the 303 tractor fluid. I better drain it out of the old 9n. I'm not even sure what brand of 303 I used. What is everyone using in their N's for hydraulic fluid?
(quoted from post at 21:59:17 10/08/19) I think after reading about the problems with the 303 tractor fluid. I better drain it out of the old 9n. I'm not even sure what brand of 303 I used. What is everyone using in their N's for hydraulic fluid?
(quoted from post at 19:59:17 10/08/19) I think after reading about the problems with the 303 tractor fluid. I better drain it out of the old 9n. I'm not even sure what brand of 303 I used. What is everyone using in their N's for hydraulic fluid?
(quoted from post at 22:59:17 10/08/19) I think after reading about the problems with the 303 tractor fluid. I better drain it out of the old 9n. I'm not even sure what brand of 303 I used. What is everyone using in their N's for hydraulic fluid?
(quoted from post at 07:19:53 10/09/19)(quoted from post at 19:59:17 10/08/19) I think after reading about the problems with the 303 tractor fluid. I better drain it out of the old 9n. I'm not even sure what brand of 303 I used. What is everyone using in their N's for hydraulic fluid?
Kenny have you added a wet clutch pack or inboard wet brakes to your N? Unless you have, the only reason to change to UTF is to give yourself a warm feeling.
(quoted from post at 07:37:49 10/09/19)(quoted from post at 22:59:17 10/08/19) I think after reading about the problems with the 303 tractor fluid. I better drain it out of the old 9n. I'm not even sure what brand of 303 I used. What is everyone using in their N's for hydraulic fluid?
And if you are a big believer of oil myths you can use a plain mineral oil. This type of oil is sold as SAE 90 GL1 gear oil and lacks the EP additives that provide wear protection in spiral bevel final drives. [b:23389fccde]API classifies it as suitable for use in manual transmissions [color=red:23389fccde]and lightly loaded final drives.[/color:23389fccde][/b:23389fccde] Never recommended by Ford and only used briefly by them during wartime rationing of EP gear oils.
TOH
(quoted from post at 09:03:24 10/09/19) I'm on a Model A Ford board where oil posts are prohibited. That's because they all follow the same pattern:
ANSWER: modern technology has provided superior products that will perform much better than what was used 90 years ago.
RESPONSE: I do not care what tests, experience, petroleum engineers or even common sense says, I will only use what was available when the tractor was new. Do not confuse me with facts.
It's like arguing religion or politics with some people.
Here is one article you might find interesting:
https://www.tractorlife.com/2018/06/19/perilously-obsolete-the-dangers-of-303-tractor-hydraulic-fluids/
There are plenty more articles re the benefits of UTF over common gear oil. Google is your friend.
75 Tips
(quoted from post at 17:03:54 10/09/19) Do you know the complaint was they didn't put on there labels it was to be used on tractors before 1975. I have used it on all my tractors. never had a problem. there new 303 oil does have the date on them. orchelns farm and home sells a lot of it.
(quoted from post at 06:39:31 10/10/19) Dang it you guys, now I'm being guilt-ed into actually using the cheap 303 I bought 2 yrs ago as the "Flush oil" I had bought it for.... Put it in a new to me basket case 3400 and got everything working right. I had meant to drain it and replace with a better fluid (premium UTF), 34hrs on the machine now and haven't done it.
I noticed the 9N with fresh 90wt from TSC is doing well but in winter it is SLOOOOOOOOW to warm up enough to be usable. Maybe it'll get some premium UTTF too.
Thanks for condensing the facts for us TOH, I didn't even need to call you this time.![]()
(quoted from post at 09:46:27 10/10/19) Yeah, the 9n only runs about 1/2hr at a time once a week or so. The 3400 is typically 20 minutes every few weeks.
I use them hauling firewood & dirt.
Last night the boys and I moved a batch of Cherry from the neigbor's fieldtreeline to our property to split later.
(quoted from post at 19:29:37 10/10/19) I doubt it, just digging some dirt or dragging wagons of firewood around. Haven't checked its condition since I flushed it and rebuilt the pump 2 yrs ago (maybe 4....) I'm putting checking it on this fall's to-do list.
