Need electrical advice-LED Dimmers
Pappy
Put a new LED lamp in the kitchen-----it is BRIGHT! Wife wants a dimmer. It's on a three way switch. Question: Will I have to use two dimmers, or will I be able to get by with one? I appreciate all help.
(quoted from post at 11:16:04 01/30/22) Put a new LED lamp in the kitchen-----it is BRIGHT! Wife wants a dimmer. It's on a three way switch. Question: Will I have to use two dimmers, or will I be able to get by with one? I appreciate all help.
There's a sorts of "three-way dimmers" on the market, you only need one.
But not all LED's are "dimmable" and not every "so called" dimmable LED is compatible will every "so-called" LED-capable dimmer.
Better check the box on the LED lamp first. Some of them are not usable with a dimmer. Another option is many LED lights have a switch on them when you install them that has several light levels you can select from.
John T might be the one to answer this. On my old car, the dash lights were very dim so I replaced them with LED's. The rheostat on the headlight switch wouldn't dim them so another car nut said get a 'Pulse Width Modulator'. I installed it in the dash and it WORKS. This is for a 12 volt car, so I don't know if a three-way switch exists with this function.
Our dining room table light is on a three-way circuit, one dimmer. We switched fixtures there to all LED, and I had to change the original dimmer to an LED specific three-way dimmer, as the original did not function properly throughout the full range. That was in early 2020, by now I suspect nearly all dimmers are LED ready
One LED compatible dimmer is all ya need. There will be an adjustment to make for how low it will go, as LEDs will get to a certain point and either turn off. Another option, if the new bulb is too bright.......maybe just get a lower lumen bulb instead?
Only if you have some need to dim from both locations but normally one dimmer. Worst case you walk across a room to the switch.
If the brightness now is the trouble and she just wants less bright you could simply look at a bulb of a different temperature range and less power. Lots of choices, but as others said, not all are dimmable but the packaging will be plainly marked.
Actually, AC light dimmers work similar to a pulse-width modulator. Dimmers use a device called a triac that turns on the power for a fraction of a cycle. Triacs can only be used on AC power because they have no way to turn off once they're turned on and rely on the AC zero-crossing to shut off. PWM dimmers use a different solid-state switch (probably a MOSFET) that can turn power on and off. (MOSFETs haven't replaced triacs in AC dimmers because triacs are much more efficient than MOSFETs and don't require heat sinks.
