Dave in CT
I am performing a 12-Volt conversion on a recently purchased Super H. I have Bob Melville's wonderful "Farmall M and Super M 12 VOLT CONVERSION" which I believe will serve in my case as well. I'm just looking for confirmation on a slight alteration to the usual conversion procedure.
I'm replacing the stock 6-volt coil with a 12-volt Standard brand UC16T coil which has "USE WITH EXTERNAL RESISTOR" printed on the side (it also has "1306" printed on the side). I thought the external resistor was to reduce the 12 volts to 6 volts so one could use the old 6-Volt coil. Will I still need that resistor (which I have) when using this coil?
Thanks for your time.
