Need help Dana 44
Geo-TH,In
I have to pull the pinion. Bearings feel like they are not running smoothly.
I don't think they spot well locking nut in place and factory, do they?
A little grinding and I got the nut off.
I ordered an install kit. Got new pinion bearings and a nut.
Now I can't get out. There's a big washer between the bearings and end of
Pinion. How do I get the bearings and washer off?
George
try this for the 3rd time.! u need to press the pinion out of the brgs. then remove the seal and brgs. you will need a new crush sleeve as they are a one time deal.
that crush sleeve goes in-between the brgs. then tighten with an impact till you have preload on the brgs. I go by a stiff turn. book will call for so many ft. lbs. of pull using a spring scale. at least that's the way it is on 1/2 tons . don't know if this is the same set up.
how do I know he know's? just giving info. as not many people know differentials or a clue how to set them up.
I can post instructions and diagrams but I need to Know what size ring gear you have ,, 10 1/2", 9 1/2", 8 1/2" .
!! Before you remove the pinion gear you need to measure the pinion depth so you can install the new pinion gear at the same depth!! It is not complicated but neglecting steps will cost you time and frustration. Do you have a dial indicator to measure with?
As long as only bearings are replaced, pinion depth will not change. Even if it did, it would not be by enough to matter ON A MACHINE THAT ONLY GOES 5 MILES PER HOUR!!!!!!!!!!!!!
Most bearings are manufactured to precise dimensions. Just take the old ones off, put the new ones on, and keep all of the shims in the same position as they came from and everything will be fine.
NOTHING WILL CHANGE TO ANY DEGREE REQUIRING ADDITIONAL ATTENTION OR ADJUSTMENTS!!!!!!!!!!!!!!!
Let's not overthink this. The machine only goes FIVE MILES AN HOUR!!!!!!!!!!!!
(quoted from post at 14:03:34 04/12/20) As long as only bearings are replaced, pinion depth will not change. Even if it did, it would not be by enough to matter ON A MACHINE THAT ONLY GOES 5 MILES PER HOUR!!!!!!!!!!!!!
You are spot on about not over-thinking the job, when I see the evidence here, I see previous work done by a non thinking hack or someone that is getting by in a pinch.The welded nut tells me the pinion preload is not correct, tighten that nut to torque and the pinion probably wont turn , or even might be too loose, I'm not there to check these things, but many variables could be sorted out before going back together.
Agree 5mph is not speedy, but did you see the shattered spider gear teeth? When that diff was schlumped back together last go around there was no good to come.
I will stand aside if there is no need to offer info.
First thing is that the pinion depth is a function of the housing - not the bearings.
It has been a while since I set up a Dana, but as I remember it, there is a shim behind the pinion bearing that sets pinion depth. Pinion depth is measured by using a set of measuring blocks in the bearing bores in the housing and putting a dummy carrier in place of the carrier that has the ring gear on it. Then, the dimension is taken from the dummy carrier to the measuring blocks. Then that dimension is converted by a table to the required shim for the pinion. Then, if there is a marking on the pinion like +1, -1, or something like that, that number is added or subtracted from the shim for the pinion depth. The bearings do not figure into this as they are precision made to a specific dimension.
Next, the shim stack between the bearings is used to set bearing preload.
This setup method is correct for highway use vehicles. A 5mph terramite should be quite forgiving if the pinion depth is not exactly correct. After all, what is the result of incorrect pinion depth? Potential gear whine? And at what speed? Even if those gears howl out loud, it would not start until way faster than this terramite will ever go. It will not cause excessive wear or stress on any of eth components.
Bearing preload would be more critical to bearing life.
I have set up a few rears in my days. Dana rears were always a bit of a pain because of the way they are put together with the carrier shims inboard of the carrier bearings. Also, rounding up the necessary fixtures in a dealership environment is a chore in itself. Many of the mechanics are too intent on beating the flat rate to put things away after they use them. Makes it a real treat to round up the tools you need for the job at hand.
Pinion depth and ring gear backlash determine the contact patch of the two gears. The contact patch is checked after final assembly. The pinion is first to be installed for reassembly. The pinion depth can be measured from the split line of the carrier side bearings by placing a straight edge on the split line across the width of the housing above the pinion gear.If the depth of the old gear is measured at say at 4 3/4", (or 4.7345" depending on ruler or dial indicator), installing the new pinion with the larger pinion bearing pressed on, then the shims from the old set up and the new bearing cup in place the pinion depth can be measured and adjusted without pressing the large bearing off. The shims are placed under the bearing cup in the housing for pinion depth, note the illustration above. Duplicating the original measurement is no guarantee of perfect contact but only a starting point. The preload for the pinion bearings is adjusted by the shims under the bearing cup of the smaller of the two pinion bearings. When the pinion nut is torqued the shims replace the crush sleeve to limit preload. Preload here keeps the contact patch consistent, the pinion cant move back and forth when changing from forward and reverse, a few thousandths slop is not good for the gears, and too much preload will hurt the bearings.The preload is measured in inch pounds of force to turn the pinion without the carrier installed.You dont have to have a dial indicator or inch pound torque wrench to put the deal together so it will last under load, but you have to feel and see the important nuance details.
The loads on that teramite gear set are extreme with a heavy load in the bucket and making tight maneuvers around the shop.
Pretty sure everyone agrees someone was in there way before you ever bought it. Normally I'd say just changing bearings and make sure shims are kept the same you might be in good shape. But this is not normal ! Who knows what shims may of been removed before ? Some careful reading of any service info you can find and some measuring is in order. Should be some service info out there since that is the same one Jeeps use.
and the backlash should have been checked before pulling the crown out. when using the same crown and pinion you want to keep the backlash as it was originally.
Mike,
I found a video on my Dana 44.
Jeep and Jaguar uses it.
It was very helpful.
I think I can get it done the right way.
My limited slip disks broke, damaging the gears.
Pic is a small amount of the metal filling I've removed.
Impossible to remove bearings without a special puller.
The old carrier on the right,
New carrier on left.
I need to make new carrier same height as old.
Another video shows easier way to get this done.
I'm learning a lot watching others rebuild dana rear ends that have no crusher washer or crush spacers.
George
I would like to see the videos : )
Its possible to get the side bearings off with out a special tool you would need a bearing press but don't hold your breath one slip and the bearing cage it toast..
I guess all you are after is the shims bust the cage off run a bead of weld around the bearing race it should slip off are give you something to drive again... Warning the race is extremely hard and will shoot off debris much like being shot out of a gun...
You could cut a slot in the race and crack it open with a chisel it will take a deep long diagonal cut...
I have worked on rear ends for many moons and ya really do need some special tools . A bearing splitter some slugs a dial indicator and 600 Ft. torque wrench and a flange wrench . snap on has a differential bearing puller set ( have one of them) bearing splitters all mine art OTC , a press is nice but if you make up drivers an 4# hammer works well some were made up tools as needed and the biggest help on setting up A Dana is the set up tool kit to get your pinion depth set up before you press the inner pinion bearing on . That is the biggy getting the pinion depth set according to the gears .
The Dana 44 has no crush sleeve and no crush washers.
I've gotten many good tips from watching U tube
videos.
Also learned the axle tubes have silicone to seal
them. I think I can do it with tools I have and a
life time redneck engineering experience.
Geo.
