Need help identifying 2 bottom trip plow
RaspyStorm
I need help identifying this 2 bottom trip plow for my dad. We found IHC all over it & the two main beams have PO17184 & PO12572 on them. We are going to restore it and want to paint it the original colors. Also if anyone know roughly when this plow was made, that would be great. Thanks.
Raspy Storm: By trip plow I assume you mean trip hitch. Most trip bottom plow didn't have P&O numbers. I have the parts book for Little Wonder No.4, it's not that.
I don't have parts book for Little Genius anymore. Does it have a tail wheel with linkage going to left front wheel rockshaft, which in turn makes tailwheel lift rear of plow? If so you probably have a Little Genius No.8. 10 times as many No.8 as all other Little Genius combined. If it is a Little Genius No.8 built between 1928 and 1962. Most other Little Genius were big frame plows for deep plowing in trash.
Now, if it has no tail wheel or fixed tail wheel, could be Little Wonder 1 or 2.
The parts mentioned were used in several IHC plows which were manufactured from 1927 through 1936.
PO12572 was used in the Little Genius 18" Sulky and Gang plow and the Little Genius #8 plow.
PO17184 was used in the #8 little Genius Plow, the #8 Rice Plow, the 18" Tractor Sulky and Gang Plow and the #10 and #10L plow.
This information was taken from the No. 84 PO parts catalog.
My guess is that the plow is a #8 little Genius plow, probably a 10, 12 or 14" unit. A photo would help us identify the plow.
