Need help identifying Ford backhoe
J_clopp
Looking for help identifying the year and model number of my old ford backhoe. All I know about it is it has a 4 cylinder Diesel engine. I can t find any markings on the bell housing. The engine block has 609018 stamped on fuel injector side. It s been a great tractor but needs rebuilt. Sorry about the poor pictures. I started tearing into the other day. Any help is much appreciated. I can remove the tarp and take some better pics if needed.
(quoted from post at 05:52:41 08/10/19) Looking for help identifying the year and model number of my old ford backhoe. All I know about it is it has a 4 cylinder Diesel engine. I can t find any markings on the bell housing. The engine block has 609018 stamped on fuel injector side. It s been a great tractor but needs rebuilt. Sorry about the poor pictures. I started tearing into the other day. Any help is much appreciated. I can remove the tarp and take some better pics if needed.
Look on the flat spot on the bell
housing - just above and behind the
starter. There will be some numbers HAND
STAMPED into it there. You probably will
need to scrape some paint and crud off
to read them. Faithfully copy them down
and post them here. Someone will know
how to decode them.
I checked the flat surface behind the starter for numbers. It s so pitted up that I can t make out any numbers. I would attach a pic if I could. Is there any other location I could look? I think it s a 1800 or 4000 industrial series. It has a four cylinder diesel motor and a five speed trans. It also has power steering. Like stated before the engine is stamped with 609018. If I could id the motor, would I be able to find a rebuild kit for it without knowing the tractor model number? Any advice is appreciated.
