Need help identifying sickle bar (international?)
arickdm
Can anyone identify this sickle bar? Im assuming its an international because that all my grandparents collected. Im hoping it will work on my 31 regular
This post was edited by arickdm on 07/03/2021 at 04:28 pm.
Sorry, your picture doesn't show up if you tried to post one. Not always, but in many cases new users have to have 5 or more posts on record before the site lets them post pictures, due to site spam filters. Another option is to go down to the Site Comments Forum and ask YT Support for permission to post prior to that. You can try going down to the Test Forum and making several posts there to get your post count up, trying to attach your pictures to each post. That may work after you make several posts. Then make your post here again. It may not work immediately after you get past the 5 posts, if not, you might try logging out and back in at that point. There is a size limit as well, I think it is a total of 7mb per post (be it one picture or the total of several). Some pictures (often taken with phones), are too large and have to be reduced before they will post.
It definitely looks like a Ford to me. For
your regular you will probably need a
mounted sickle mower. I don't recall IH's
model but something like a John Deere no 5
or 8 would work well. I have a 5 I'd sell
if you are interested in it.
I would hope that you know that is a 3 point mounted implement. Unless your regular has been fitted with some type of
aftermarket 3 point hitch you can not mount that mower on it. I cannot tell you what model of an IH mower you need for
your Regular but maybe someone will chime in with some info.
IH did make a fully mouinted nower that fit your tractor but they were very rare and probley all now in the scrap yard. So next would be a semi mount mower that bolts to the tractor drawbar and has either 1 (JD No 5 or No 8) caster wheel or IHC single wheel caster wheel mower No 25 oe no 27. Then COOP, Cockshut, Oliver, Massey made a 2 caster wheel mower that would work. This is as far as hooking mower up to tractor but not the PTO shaft as you would probably have to have a costom made extra long shaft with a 1 1/8 soupler on shaft as later standard in 1 3/8 coupler. The PTO on a regular and even an F20 is under the differential ubless you have the very rare factory conversion to use a standard length and diameter PTO shaft. You would also need that PTO conversion to use any trail type PTO powered mower. Lot cheaper to get a different tractor than to get a PTO shaft to use any of the semi-mount mowers that to get a PTO shaft made that will work.
