This morning, away from the house, my trusty 640, with 12v conversion, suddenly wouldn't start. Cranks, but sounds like no fire. I had a roll of wire with me, so I tried hot-wiring it from the B+ to the coil. It started immediately. Got it to the barn. Disconnected the jumper wire from battery to coil, checked volts from the ignition switch to the coil and got full battery voltage, but it would not start. Put the jumper back on, and it started instantly.
I tested the key switch multiple times with the multimeter, and it worked every time. The only other thing different is that the voltmeter on the tractor also stopped working, but it is not in the direct circuit from the key switch to the coil, and I don't see how it can be related.
I'm stumped. Will appreciate any help or advice that someone can give.
Thanks.
Thanks.
