Big mac@112954
When I bought this tractor I knew it was going to need work. I drove it home (7 miles) and it seemed to run well. The next day I pulled a bush hog thru 2 acres without a problem. On the third day it would not start. After a good look at the wiring it was evident that who ever did the 12V conversion was not aware of what a good wiring project should look like. I stripped the it clean and replaced the key switch and starter button with 4 pole key switch. The 1 wire alt. was not charging. I had it rebuilt and bought a new battery. The previous owner told me that the tractor had burned up a couple of coils. I bought a tune up kit that had almost every thing. I tested the starter relay. It was a 4 pole and tested ok. Now its all back together and when I try to start it I get back fire thru the exhaust. I set the points at .025 and the distributor was not tight when I tried to start. The unit turned clock ways as far is it could. I moved the distributor back to approx. where it was. It was still backfiring. Where do I go from here? All input is valuable to me and thank you in advance
