Need help with a spike tooth harrow
300guy
I will try this here and on another forum but I have an old Ford 16 foot spike tooth harrow. Several of the teeth loose and I wanted to know if anyone knows of a place to find something like these holders to replace the loose ones. I have some I am going to try and weld on and those are the ones that have two pieces that wrap around the tooth. I also have others like the single wrap piece wrapped around the tooth. They work fine and tighten nicely. I may have to try a round rod and bend it around the tooth and weld a bolt onto the rod. But that is a LOT of work for what I need. I have replaced a couple with cable clamps but that requires drilling an extra hole and if I need to replace one out in the field, I don't always have a drill to take out there all the time. Only if I take one with me from home which is 2 hours from the farm.
May try Agri Supply. They have had the spikes in the past. I want to think they also carried an assortment of holders.
I've got one i put on the back of a field cultivator that the spikes are welded into the tube then the tube will pivot to adjust angle. I guess when the teeth wear down so far you junk it or weld on new spike teeth.
I have spike several broken up spike tooth harrows in the junk pile plus 2 or 3 that are usable. Those teeth of various style have and will never come loose and while some teeth may be wore down most would last another 100 years. I would use some heat and Pent. oil and dis-assemble some to uasable parts but I am afraid it would not be be worth the effort. I don't know your location but shipping used parts plus thier lack of value makes it hard too come out even. Cleddy
