Need help with big Wisconsin engine info.
Figured I'd give you guys a shot at this because it appears the stationary engine group has some knowledge of Wisconsins.
This is a big 1929 4"bore x 5" 6cyl model H engine with overhead valves. I've got 2 of these to rebuild one which is a power plant and one in a crawler. Neither engine is apart yet but I'm 98% sure I'll need to bore and replace pistons. Just wondering if any of you out there might have a manual/catalog that will
give specs, part numbers or cross references to pistons, valves and valve springs.
Thanks!
