need help with CT 332
44A
Boss has a JD CT332 skid loader. It starts good runs about 5 sec then dies. We have looked over all the normal stuff like fuel cap plugged, jumped key switch to bypass, all fuses are good, swapped relays, etc. We don't get oil pressure light at all an don't think there is a problem with that. When we jump the hot wire to fuel shut off solenoid the unit will run. We have checked continuity in the wires to that solenoid an they check good. What would be causing the solenoid to lose power under normal operation with no jump wire?
Make sure your anti-theft is not active. Those machines will start and run for a second or two and immediately die if the lock code is not entered. This is a common issue with those models, because people believe there is a fuel issue, but it actuality it is locked out.
