Need help with John Deere 1010w 4 Cylinder gasoline Main bearings
JWW
Hi all,
I‘m relatively new to the rebuilding world and am having an insane time finding Main bearings for my early model 1010w.
Unfortunately, my 1010’s engine serial numbers are missing. It’ an early gasoline 4 cylinder model with .010 inch oversized bearings that have no hole or groove in them. I’m hoping someone can point me in the right direction as these bearings are all that’s left between me having a great little working tractor or a really large boat anchor. I’ll attach some pics of the old bearings. Any advice would be appreciated.
JW
With tractor serial # below 031,000 rear main thrust brg .010 should be part # AT24425 & other .010 main brgs are part # AT24414. See following links.
https://partscatalog.deere.com/jdrc/sidebyside/equipment/59702/referrer/navigation/pgId/101883
I didn't strike thru, this site did it. possibly because this site lists the main bearings but says not available online, lease call.
Thanks for all the advice. I’ve looked all over for the bearings you guys mentioned but no one has had any in stock for at least the last 9-12 months.
Take a cap and the bearings to a machinist who can measure them it’s not quite as easy as taking a rod in that he can measure both sides with it bolted together but he should be able to help you out especially if it has a part number stamped on it there’s a lot of suppliers who will list something in their catalog for them to try
  • Like
Reactions: JWW
