Bill Knecht
Can anyone help me with this problem? I installed a new fuel sensor on my 1971 Massey-Ferguson 135, and it now leaks fuel out the top of the fuel tank when driving, as the fuel sloshes. I tried gooing it up with Form-A-Gasket, but no luck. Then I tried putting nylon washers over each of the 5 hold-down screws. No luck. What's the trick to stopping this leak? The gasket itself is cork, and the seal it needs to perform is obviously complex, as you can see from the picture. It's not a simple seal of two flat surfaces, and fuel clearly leaks out of the screw holes.
I apologize if this has already been discussed. I tried the Search function, and it came back with too many pages to read them all.
