Hardwood62
Ok so I tore it down to get the gunk out of it, was a sticky gooey mess - would not pump out injector ports. My question is after I removed the pump head and pump rotor and cleaned them then after I inserted the shaft, added some WD40, and spun it with my hand it would only freewheel about 1/4 turn - I have seen videos where it showed it freewheeling about 2 or more turns ... what is normal? I was thinking of using a brass shotgun brush or a cotton gun brush with bore honing paste to get it to freewheel better ... not sure if this is advisable hence the question. Also should the pistons fall out of the housing ... mine will about 1 out of 5 times I turn it on its side - usually need a bit of a push??
Any advice from you Diesel Experts would be greatly appreciated.
