Need help with Satoh 650G
I have a Satoh 650G. I was moving a railroad tie with my blade and budged the tie. When I went to lift the blade the hydraulics would not work. I have taken apart the lock valve and everything looks good but it looked like some o-ring material and I do not know where that came from. I can use the 3-pt manually but the lever will not work. Can anyone help?
Check the pump drive...the pump is on the front of the engine and the drive it two flate pieces of metal bolted together to clam shell over a flattened portion of a shaft bolted to the crank pulley . Mine did the same thing when the drive came loose and wasn't spinning the pump.
