Need help with sickle section ID
So here is what I do know. The rivet holes are 2 on center and are countersunk from the bottom. Needs to be 3 wide and 2 1/2 long. Only identification on it is a O between the rivet holes. I need them for a Gleaner floating cutter bar on my Gleaner F2. The plate on the head says 15 sn F50551. Numbers on the guards are FS-7-52 and 232157. Any help will be appreciated!!
Have you tried the nearest AGCO dealer?
I've been amazed many times by the amount obscure parts they can stil supply.
(quoted from post at 13:04:53 07/30/21) So here is what I do know. The rivet holes are 2 on center and are countersunk from the bottom. Needs to be 3 wide and 2 1/2 long. Only identification on it is a O between the rivet holes. I need them for a Gleaner floating cutter bar on my Gleaner F2. The plate on the head says 15 sn F50551. Numbers on the guards are FS-7-52 and 232157. Any help will be appreciated!!
heck with Webb Cutting Components https://www.cuttingcomponents.com/parts/sickle-sections.html.
You will have to call them, as the site doesn't give details on which have countersunk mounting holes. 1-800-578-1480
(quoted from post at 08:22:11 07/31/21) Never heard of a section with countersunk rivit holes.
Case IH haybine twin drive knife where the 2 knives overlap they use a tiny tapered hex head bolt that sits flush in a countersunk hole in the section.
You can buy the sections this way or in a pinch using the right size drill bit make your own chamfer on it.
They drill quite easily.
