Need plow ID help
fatbanks
Hello everyone,
I'm trying to identify and to get some replacement parts for an older plow that I recently started working on. one of the bottoms is removed in the included pictures.
moldboard stamping number is 20H1477
frog stamping number 20H1487
the plowshares that were removed appeared to be a 2 piece design with the longer blade stamped with 20H1473 and SOLID MM
I'm mostly interested in new shins and shares as everything else seems to be in a serviceable condition. Let me know if you all need more info or have anything to share. Thanks!
This post was edited by fatbanks on 05/02/2022 at 04:26 pm.
Based on the lettering I would guess a Minnnie Mo plow though it could not be also. Look at Osmundson site for more plow information in the way of wear parts for it. could also use on old plow points and cut in strips for the point by welding a couple bolts to the back of it.
Does that have a separate tip for the plow share from the plow share? Interesting.
I think as others mention using old shares to create those shapes might end up being the fall back plan.....
Paul
Thanks for the replies everyone. I was hoping I would luck out and something modern would fit the bolt pattern, but it sounds like a little fabrication is in order. I'll also reach out to Osmunson's to see if they have something floating around.
I added a picture to the original post with the share attached to the bottom
20H1473 is a 16 share for Moline RP bottom. The points are separate. I have some NOS points and a 14 share. If you can get a number off the shin maybe I can match with what I have.
Phone 715-743-2220
Buddy
