Need suggestions for a dependable backhoe
HDN
I plan on selling my ~1960 Ford 1801 Industrial tractor with a loader, and I want to replace it with a backhoe. I plan on using this backhoe around the house and for other projects involving digging and somewhat heavy lifting (like truck engines and transmissions). I'm fine with getting something older than made in the 1980s, but I need to be able to get parts for it and perform maintenance without needing another tractor with a hoist for help (that's a problem with my current tractor - I have nothing to help remove its cast iron nose to replace the radiator hose).
Does anyone have any suggestions? I was thinking Case and John Deere were no-brainers, but I'm interested in Ford backhoes as well if they meet the above requirements. When mentioning models, please specify model years if they make any difference.
Ford 4500. Older but dependable.
You can buy a tractor with FEL and a 3 point backhoe attachment. Get one with its own hydraulic tank and pump versus one that runs off tractor hydraulics.
Nowadays don't overlook the versatility of a mini excavator. I have owned a Deere 210c loader backhoe for years and about 4 years ago I got a 7000lbs mini excavator, it sees a lot more use than the backhoe nowadays.
Ford 555 backhoe.
Mini excavator is also great but no front bucket and would need to haul it if moving any distance.
I've run quite a few of these in years past, what comes to mind is JD '10 series, Case 580's, Cat 416, Ford 555, 655.
I've run Dynahoe, JCB too, from an operators point these seemed pretty decent, lots of common models, but am not sure in the present time parts support for each. I found a low hour 555C about a year ago, good condition, had the shop go through it, and have made good use of it in the little spare time I have. I don't see any leaks, hoses are aged, will be checking on those, replace etc. Worst ones have been replaced. I know I can get it worked on if anything serious, believe parts support to be good, they made a lot of them. Need to find the correct fuel cap for this one, CNH says NLA, odd. That and a muffler, seems to have a hole in it. Strong machine, you can wiggle this thing around to where you need it. It has FWD, which I think is preferable, but not completely necessary either.
When I got my 655A I bought a new OEM fuel cap. It has a maybe a 1" diameter tube hanging down a few inches. Maybe they think that somehow deflects the return fuel flow in the filler neck?
As a mechanic I'll throw in another plug for the Ford 555 machines. They made alot of them, they use parts that are still available through the OEM, or aftermarket, and they are relatively easy to work on if there is a problem.
The fords are good but my preference hands down is a case 580. They have a Cummins motor and parts are no problem at all. Plus in the world of backhoes for used buckets and attachments there will be much more options with a case. I have a 590 super L and unless times got really tough around here I?d never do without one
if it were me I would fine an old gasser. doesn't sound as though you may not use it that much. diesels are better but they need to be used more often than gassers. the trick is to find a good one regardless of what you buy. case is probably the best back hoe made. 580s were made in abundance and parts are easy to find. I had a case 530 once. nice machine but not as powerful as the 580. I would try to stay around 1980 or above for parts sake. take you time. location will make a big difference on price. ford, jd,case there all good but the trick is to find one that hasn't been abused and you can trust the seller. take your time. understand that each back hoe has its limitations. search the net for information on any model your thinking about buying. lots of good information out there. good luck on whatever you buy.
Not sure of the variants of fuel caps on these, the one it has looks the part but does not engage the filler neck which is not very tall. So it just rests there, saw they have one on here, hard to tell if correct fit though.
Don't buy a backhoe. Buy a mini-excavator instead. Get one with a thumb and a blade and it will do pretty much anything a backhoe will do and more.
I also like the 555 Fords. They may not be the fastest, but they'll lift a whole lot more than they have any business lifting. 3400 pound cement blocks, the 555B will lift out of a dump truck when the 580SM struggles. And they are much better in the mud than the wide-tired Case. The skid loader tires on front of a Case also have a tendency to blow the sidewall over the bead under load on uneven ground.
Even with front wheel assist, I could balance the 555B on the back wheels, walk it around the Case, grab onto the front bucket with the hoe and pull it through the mud.
