need t340 parts
dcliffw
i need pinion 12 tooth gear, the 2 bearings, and seal. if you have these parts, or know where i can get them i would appreciate hearing from you. thankyou, clifford.
cliff, do you need bearings and pinion or just pinion? your original post said "bearings came apart" the part number you listed was for a pinion only. this number is correct, however as you probly know, go into an ih/case dealer and say the word t-340 and they freak out. i have the bearing crosses for some other suppliers. sorry i dont have another number for the pinion. this is weldable though. i have put several teeth on before. id be happy to weld for you, or talk to your welder of choice if that helps. i am confused as to how this pinion lost teeth and the sprocket drive is ok as are the bearings. by all means, not that im saying your wrong, but normally the bearing is the culprit that leads to other issues. if you need more info email or call ashley at 606-845-8607. im in the shop from 9-4 weekdays. thanks for you post and hope i helped.
Bearings- M1210EL Dalton Bearing. Drive pinion- Juniors construction parts (I think) 306578R1 Bearings around 75 bucks ea, gear around 200 bucks. In stock. Just ordered them for both sides of my 340. Seals are 60mm by 90mm by 8mm. They have them too. Good luck
