need to clean
If it's apart, have the block boiled or baked at a machine shop.
If it's all together and a working tractor there's no substitute for a scraper, a stiff brush lots of ELBOW GREASE and some good heavy-duty degreaser detergent stuff!
Glad Bob emphasized ELBOW GREASE. A pressure washer along with the degreaser also works, but be sure to cover distributor and other places where water under pressure may enter the enclosed places you don't want it to be.
ditto what the others said..
mechanically remove the heavy stuff.. wire brushes, screwdrivers and scrapers.
use degreasers like petro based ones like engine brite.. or even kerosene in a sprayer.. then you can go over that with soemthing like spray on oven cleaner ( 1$ at dollar store ).. and then use the detergents like simple green and purple stuff and a pressure washer being carefull around the electronics, and gaskets / seals.
soundguy
I found a wire round brush on a drill worked the best for me. It seemed to work great on the cast Iron, but not so hot on the metal. I used napa degreaser first, wire wheeled it with a drill, and then pressure washed it.
