(quoted from post at 00:06:07 02/22/21) Try this, double check availability.
Part link
(quoted from post at 11:23:57 02/22/21) Sorry, got off a line while looking at my phone. The
42040D number is correct, see link. Those are a little
more spendy, I would probably track down a used
one, should be plenty around. Any idea what caused
it to dish out? Did the end of the valve just wear down
that bad? I assume you are replacing the rocker arm
for that valve. Is this a complete rebuild, did you look
at the cam lobe and lifter for that valve is that all okay.
Make sure you run it with the valve cover off and
make sure oil is getting up to all the rockers.
Part link
