Needed Case 611b clutch pedal
(quoted from post at 01:37:15 05/02/23) Broke my 611b clutch pedal. Anyone have one they would like to sell?
Can it be brazed? I will cross reference it and see what other models it was used on besides the 511-b and 611-b. Chuck Machinist
This post was edited by chuck machinist on 05/01/2023 at 06:13 pm.
(quoted from post at 18:04:44 05/01/23)
I will be traveling to Iowa around June 23rd from Norfolk VA to Charleston W,Va to Indy to Bloomington Ill then to Marshalltown Ia.
I can get you one around that time frame. Where do you hail from? CM
I am in michigan
Conner 9988 texted me and said the 400b, 600-b ,430, 530,630 Com and their construction counterparts will fit. Best of luck CM
my 411b somehow was broke midway to foot pedal part.
i ground it down at angle,used high content nickel rod and welded
it 1 pass let it cool welded another pass till it was bigger than the
rest then ground it smooth. high nickel rod isnt cheep but it is
great on cast iron and cast steel if you take your time and keep
slag out
