Needing a rim for my garden tractor
Brad Gyde
Guys,
I'm looking for a rear rim for my JD 175 hydro garden tractor. I had to do some rear end work, and had to end up cutting off the old one.. heated it hot enough that it was starting to melt.. still was stuck on.
I went to mother deere.. I really don't want to spend that kinda money for a rim, considering I'm still not sure the hydro is fixed.
I've found a few rims, but none have the right axle shaft size.. all have been too small.
It appears that I have a 1" axle. It has a single keyway (that I forgot to measure)
The center hub seems like it is about 4 1/4" long (wide.. whatever you wish to call it)
It's a 8" dia rim, by 7" wide as mother deere says.. and had a 18x8.50-8 tire on it.
I've called a few places.. and I guess they'll never call back. I've been everywhere close.. still no luck.. so I'm hoping someone here can help me out
Thanks in advance,
Brad
A good way to remove those rims that are stuck to the shaft - Weld a large nut to the outside of the hub - screw a proper sized bolt into the nut - it presses on the end of the axle and pushes the wheel off. Works good on Troy-Bilt tiller wheels.
Paul
Old,
For some reason I can't seem to get your email.. But yes, I'm interested in discussing a wheel.. I think dad is gettin tired of comin down and mowing my yard LOL..
Brad
Brad
I have a brother that lives near Lawrence, Ks that will most likely have what you need. If you are interested send me an email and I will give you his contact info. He will ship it if you need him to.
