Hi,
Does anyone have an original copy of, or a reproduction copy of the parts list for a NH 68 square baler? I misplaced mine and it will be at least a week before I can get a new copy in the mail. The online version from New Holland does not answer my question.
Group 13 Item #57 lists the sprocket as part number 80163210 with 24 teeth, which jibe with the part I removed. The part I have has no part numbers listed. The part in PDF version from NH lists as a 12 tooth, and Messicks lists it as a 24 tooth with a note as being tooth (teeth?). I've been in contact with Walt's/Unger tractor and they said the 68 they have told me that the 68 they are dismantling does not have that number of teeth for that part.
I would have preferred to reuse the part I had. The bearings on the pickup locked up a few weeks ago and I had to grind, sawzall and split the sprockets off to get at this bearing. A previous owner at some point decided it would be a good idea to weld the sprocket on for some unknown reason.
