New head gasket bad?
Just finished putting in a new head gasket. Warmed it up and retorqued without anything amiss. Ran it for about 15, was going to do the hour and last retorque, and it overheated. No water in the oil, no noticeable leaks, and no bubbles in the overflow. Flushed the radiator and and restarted, got hot in about 20 minutes of running at 2000RPMs. The radiator water is moving around but not bubbling over. The radiator is about 3 years old and I had the head and valves done by a shop and they assured me it was straight. I assume I should just pull the head again? I checked the block really carefully and its straight and no visual cracks. Getting pretty frustrated with the damn thing!
Did you remove the thermostat? Could it have been reinstalled backwards? I believe some head gaskets can be put on backwards or upside down and accidentally block cooling passages.
Sorry, should have been more specific. 2 cyl. YM240D. They don't have thermostats. The head gasket can go on wrong, but only in one way and it would be really obvious that the head doesn't have passages under the head gasket holes.
What engine oil are you running. We are in a heat wave right now. SAE 30W should be the oil to use in average temps over 86F.
Do NOT use 15W40 in these Yanmar engines, the heat takes much longer to dissipate in these diesel engines. It's the reason why the head gaskets go and the heads swell, causing issues.
Deere SCUT & CUT with a slew of Yanmar engines.
What was the actual temp of the water? Boiling or not? I don't see any symptoms noted that would indicate a gasket issue. Maybe water pump if the water isn't circulating. Small diesels seem to be really sensitive to airflow too, and often gather dust/pollen/stuff on the radiator fins.
My little JD with a Yanmar needs the fins cleaned often when mowing in dry/dusty conditions. Like every 3-4 hours of use.
New here and I see this thread is almost a year old.
YM1700
did a upper rebuild last fall, new loaded head, pistons, rings, injector pump, radiator with new over flow tank. About 5 hours on it since rebuild. Some light colored smoke at first but mostly goes away. Started overheating recently after about 30 minutes of use. No bubbles in water, no water in oil or oil in water. It will force water out of the tank overflow hard on start up the old tank cap does not have this it’s sealed. I have the upgraded water pump kit installed but it’s old and seemed to feel ok at the rebuild. The old radiator was in bad shape so I replaced it, yet with the cheaper knockoff from eBay, has anyone had issues with these? I have not retorqued the head yet so will do so, going to try a new radiator cap and the old over flow cap. Tightened the fan belt but still hot. Suspect; water pump, radiator, radiator cap and tank cap. Thoughts, or experience with those radiators or anything related appreciated. Also a separate issue with the governor on high rev after pulling back on the throttle it will stay at high rev and not come back to idle right away?
Thank you
Welcome to the forums.
Almost always you are better served to start a new thread of your own. For one thing this thread is about a YM240D with a different engine. Another thing that will often happen is people will read the first post in the thread and start replying to the original person that started the thread, missing your different/new issue. I/m not saying you won't get some replies, but there may be a mix of who's post they apply to.
