New Holland 1033 Stack Wagon
Thomas(MD)
When unloading the stack of straw, the Rams that push the straw off the stacker do not come out at the same time. Any suggestions?
Check the pushoffs. If one is bent and dragging/hanging up,that can/will cause your issue.Smear some grease(liberally) on em,that helps
Delta red is correct, have used several different bale wagons and none that I can remember ever had pus off feet that worked to gether without a load, but when pushing stack they work fine as hydro pressure equalizes and flows to pt of least resistance. they won't ever come back in together either so be sure to hear both of them hit the inner end before lowering load rack
