New Holland 56 rake
If those are the bearings you want, take the bearing numbers from the drawing used red MN gave you to a parts store or bearing house, they should be able to cross them. They cross at the parts store I use, and they cross at O'Reilly's. I didn't post the numbers I got as you need to check to be sure you are starting with the bearing numbers for the bearings you need.
Here is a Timken (pdf) cross reference and one online as well, if you want to cross them yourself.
2003 Timken PDF cross reference
Timken online cross reference
