New Holland stackliner 1000
Iknow you need to have dry solid bales an also you need to remove all rust on rear forks.Whole machine will work better if rust is removed an will improve as it get polished from use.Also you need to have drawbar at proper so forks are totally on ground.
If the wagon does not have push off feet put some fence rails or 4x4s between forks so they take the bale wieght. Should slide right off, or two jin poles into the stack and jammed into the ground, works sometimes. Popping the clutch always works when you have kids around to re-stack.
