New Holland TN65D
Shill1976
There is a blue wire that was spliced on the wireing harness at the top of the motor that has come undone. This inturn will not allow the motor to start. It will turn over but will not fire up. I am trying to find where it goes but having no luck. Once connected it started right up last time i just can not find where it goes again. I guess i need to know what all is necessary for the tractor to start then i could make sure all those items are wired in. I just dont know any help would be greatly appreciated.
(quoted from post at 10:46:32 06/19/23) There is a blue wire that was spliced on the wireing harness at the top of the motor that has come undone. This inturn will not allow the motor to start. It will turn over but will not fire up. I am trying to find where it goes but having no luck. Once connected it started right up last time i just can not find where it goes again. I guess i need to know what all is necessary for the tractor to start then i could make sure all those items are wired in. I just dont know any help would be greatly appreciated.
hi shill, and welcome :)
the is the board for ford's N tractors. you should ask this on the board just above this one, the Ford general board. while there's some crossover, more people there will be familiar with your model, hopefully.
just looked that one up. very nice looking machine, with some pretty attractive numbers. yours has a cab?
I used a test light and the injector pump does have cureent to it. I shunted the seat safety and it made no diffrence. Turned pto to active wont turn over so that works. Put tractor in gear wont turn over so that works. Put shuttle shifter in gear wont turn over so that works. I cant think.of any thing else it needs to fire up.
Injector pump
Seat safety
Shuttle shifter saftey
Transmission saftey
Pto saftey
All seem to be in good working condition. What am i missing?
