New holland Tn65d
Shill1976
There is a blue wire that was spliced on the wireing harness at the top of the motor that has come undone. This inturn will not allow the motor to start. It will turn over but will not fire up. I am trying to find where it goes but having no luck. Once connected it started right up last time i just can not find where it goes again. I guess i need to know what all is necessary for the tractor to start then i could make sure all those items are wired in. I just dont know any help would be greatly appreciated.
That tractor may be a little newer than we're
used to working on here.
The knowledge base is mostly Pre 1990s Fords.
That said, I think even some of the late
Fords had a solenoid valve on the injector
pump to turn the fuel on/off.
You could put a volt meter on that wire to
see if it is energized when you turn the key
on. If it comes on/off with the switch I
would be looking for a place to connect it to
the pump.
I used a test light and the injector pump does have cureent to it. I shunted the seat safety and it made no diffrence. Turned pto to active wont turn over so that works. Put tractor in gear wont turn over so that works. Put shuttle shifter in gear wont turn over so that works. I cant think.of any thing else it needs to fire up.
Injector pump
Seat safety
Shuttle shifter saftey
Transmission saftey
Pto saftey
All seem to be in good working condition. What am i missing?
