New Holland Tractor loader
Larry64
:? I changed the hydraulic oil in it and replaced a couple hoses going to the bucket and now it leaks down as i am driving.Any ideas of why?Just the bucket,not the arms. :?:
Typical cause would be the piston seal in one of the cylinders has started leaking.
Since they are plumbed in parallel, if either piston seal leaks, both cylinders will "settle".
If the loader circuits are connected to the tractor with quick couplers, you can "curl" the bucket up, then unplug the two hoses and see if it "holds", to rule out the small possibility that something is wrong with the valve on the tractor.
(quoted from post at 05:44:34 04/25/19) Typical cause would be the piston seal in one of the cylinders has started leaking.
There are no external leaks.I have checked that over and over.
