New Holland Workmaster 75
Trap4570
My parking brake when it is set is weak and won't hold on a grade. Is there a way to adjust or does the main brake need adjustment? Where are the adjustments located?
Thanks for any help.
I assume you mean your pedal bottoms out before the brake is fully applied. The pedal height adjustment is under
the tractor and part of the linkages if you crawl under there you will see them. Have to take the pin out to disconnect
them and adjust the threaded rod/clevice combination.
I think your workmaster is the same tractor as my Farmall 65. To set park brake do you hold up on orange handle and then step down on brake peddle while it ratchets itself tight?
