(quoted from post at 06:39:43 09/21/23) Well, welcome to the forum!
What parts do you need exactly? Some expendable parts would be available through a farm parts store. Other parts on those machines are specific to NI
& may be hard to find.
Mike
Mike
(quoted from post at 06:40:49 09/24/23) There is a ''dog'' or ''pawl'' [I don't know the proper name] inside that gearbox. I think that you'll find that it is worn out and needs replaced. They used to be inexpensive but might be scarce now. Don't pass up buying one if only to hang it on a nail for future repairs. When the dog is worn the cutter bar will drop as wanted and then raise right back up on its own. It is frustrating but easily fixed.
I mowed a lot of soil bank acres with those NI mowers. Everybody in the community had one. They were good mowers in their day.
We put a hydaulic cylinder on ours. I always wonder what all that was and how it worked. Apparently it didn't.![]()
Thanks Mike here is a picture with the parts I identified.
Lift trip lever 110-HS
Lift crank plate with stud 0476-HSA
& lift rod 0474-HSA
Check eBay for a NI brochure. They came out with a colorized pocket brochure for the 30B & 30BH that should get you close.I like the hydraulic cylinder idea the spring that keeps the lift trip mechanism in place is broken and I am using two ropes instead. I am working on painting it and will get some pictures posted when I am done. They didn't want to upload today. I still have to get the drive shaft cover done, I and going to have a bodyshop do that part. If anyone remembers the original color scheme I would appreciate knowing sense I have not been able to find a color picture from when they were new.
