Ed S.
- Location
- Middle Tennessee
A few weeks back, I posted about my New Idea 7' sickle with the pitman arm that kept jumping off the cutter bar, and then the head plate at the other end broke in two.
Well, in hopes that my ignorance helps someone else, what appeared to be my problem all along was that I had replaced the original (to me) pitman with the wrong size replacement (too short, but was the only already drilled out pitman at the farm store). Even though the length was wrong, I just moved the pitman out one set of bolt holes, which actually put it in correct register.
What tipped me off that this was an unacceptable 'fix,' was when I replaced the head plate (thank you AGCO for still carrying this part!), it almost immediately bent into an "S" shape when I tried the mower out. Thankfully, it didn't break like the original, and when I looked at it, it bent right at the end of the short pitman, which told me I really needed that extra length to support the head plate.
Since I had also purchased a 'blank' pitman as a backup (no holes, but same length as original), I dug out the original broken pitman and used it as a template for drilling all the holes and cutting the kerf for the head plate. Put it all back together, and the mower is running like a sewing machine now!
So, what I learned is: use the right replacement part and don't try to make something close work instead.
And the hay is down as of this evening!
es
es
