New issue replacing PTO seal.
78CJ
Well, I should have done some searching before tearing this apart but hopefully it will go back together.
What I did see is it appears that the sleeve that the seal rides on is worn? I assume there should not be a worn depression in it?
Ryan
These may help identify the parts. I did this job last year and found the new sleeve needed to be machined out to fit correctly, they are pressed on. You may consider a new replacement as an easier but more costly solution.
