New Project
Hello stp welcome to YT! If you were possibly trying to
post a photo here is some info on photo posting. At the
end of 2022 the forum host here changed the
requirements to new posters to be able to post photos
from a post count of 5 posts to 1 post. I believe this
change was only made on ..Modern View.. so you need
to post from there. If you if you see ..Modern View.. in
a gray bar just above the message text click on that it
will take you to Modern View. In Modern View you will
see the Classic View option in a red outlined box at the
top, just adding this as a way to verify you are in
..Modern View.. Try to post your picture in Modern. It
should go through on your second post if everything I
understood about the change is correct. This
restriction was a way to keep internet bad guys from
dropping in and posting bad pictures with hidden
viruses. Pictures post through the ..Choose files..
button or some such name just below where it says
..Upload Photos/Videos.. down lower in the ..New post
and reply windows, see photo. They cannot be pasted
into the text area as a file.
Stp, your post is confusing because when someone says "back hoe" they are usually referring to a somewhat more modern combination tractor-loader-backhoe, these weren't produced until the late fifties. loaders and "add-on" hoes were available, and this must be what you have. Asking for help to ID it is also confusing because you have already identified it as a TO35. I hope this helps.
