New PTO Shaft
I have to replace my bent PTO shaft, Question, the one I have has 2 snap rings, the one this site sells is a 1 ring shaft. The bearing on mine is fine and I want to re-use it but will the 1 ring shaft work? 1955 to35, standard clutch. P.S. I learned my lesson on using a ORC on my King Kutter.
USE ONE!!!!!!!
Compare old shaft to new one. There is a snap ring on each side bearing. Does new shaft have only one groove for snap ring? If so which side of bearing is it on? If the snap ring is facing outside will the bearing stay in place in housing? Can't remember if it sets in a shoulder in the housing.
