New to Me 446 Case
550Doug
Location
Southern Ontario
I recently picked up a Case 446 garden tractor without a mower, and it has the Onan B43M engine. The previous owner has passed away so I'm asking my questions here.
It runs great and I like the high clearance from the large rear tires. It does freewheel going down slopes but at the bottom of the slope the engine dies and won't start. I found that it blows a 20 amp fuse from the ammeter to the battery side of the solenoid. So I replace the fuse and it fires right back up. I also notice that the ammeter will read around 15 amps when the engine is at half or 2/3 throttle. So it looks to be overcharging at 20 amps when freewheeling. I suspect that the voltage regulator is non standard as it does not appear in a parts manual.
So what is going on with blowing a fuse when freewheeling?
I have posted this in the Garden Tractor forum.
I also have a post there looking for a narrow riding mower (around 36 inches) with a possible left discharge chute. I know Case has left chutes but what are some other makes?
This post was edited by 550Doug on 09/30/2022 at 04:31 pm.
They will free wheel if left in the forward position on the hydro lever. Pulling rearward on the lever puts it in retard position and
acts as a brake. Also has a foot pedal for foot brakes if adjusted correctly. Good solid mowers, have about 30 Case L&G tractors here.
Have one I put a bus seat on so the wife and I and grandkids can ride around tractor shows...
I would suspect the fuse failure has something to do with the overcharging.
Might try unplugging the regulator and taking it for a test run to see if the
fuse holds through all the functions.
Sounds like a bad regulator, or wired wrong, but a bad battery will also cause
excess charging. Does the battery stay up between uses, and will it start
without jumping?
