2510Paul
Here is my new toy. It is currently sitting at the local La Crosse WI JD Dealer. It came from Pennsylvania.
I will use a JD 4320 or 4250 to pull it. I am thinking of taking the gauge wheel off and just relying on the tractor depth and draft control to run it as I do with my 4200 JD Rollover Plow. Comments?
If I left the gauge wheel on, how do I set the tractor draft/depth control?
Paul
the accumulator is for breakaway action. Functions just like the springs on a IH 710 plow.These are good plows!
Leave the gage wheel on. Set the 'load/depth at the center of it's range. Set the 3 point so the tractor carries most of the load,but not all. you don't want the gage wheel to carry all of the plow wt. It just funtions to serve more as a guide,or to aid in those places where it wants to suck in suddenly,or when plowing extremely uneven ground.It just helps to keep a more even depth. Those are good plows! Made by Artsway on the old IH patterns. Essentially they are ('the old') IH plow.A 4320,4250 should easily pull a 4 bottom.There are many of them here. I have pulled one before. I'd love to own it! Nothing better when plowing 'rock piles'.
Just put that old '43' in 5th or 6th gear and pull open the throttle. 'Balls to the wall". If you hit a rock,the one bottom just rides up over and settles back down with barely a hiccup.No stopping required. Just go.
About $9k with shipping and everything. It sounds like a lot but price a new one, about $30k as I recall some years ago.
The wheel pivots on a bolt on the end of the arm. When you roll it,the wheel swings around underneath. gravity kicks in and releases the catch. When the roll is complete,gravity once again lets the wheel fall and the catch catches on a little hook,holding the wheel in place till the next roll over.
I hate to think about how many thousands of acres I plowed with a similar plow over the last 40+ years. LOL!
