Hi all,
Newish member here, first post, first tractor. I picked this 850 up this spring from a local seller on CL. I bought it over the winter but left it at the seller's location (he's a Farmall shop) until the snow banks around my boss's trailer melted enough to get it out. In the meantime, I fixed up the center bay of my barn to get the tractor out of the weather.
https://onedrive.live.com/redir?resid=FA8FA1420D8254D!559&authkey=!AKft4WXX21KEEBY&ithint=folder%2c
<iframe src="https://onedrive.live.com/embed?cid=0FA8FA1420D8254D&resid=FA8FA1420D8254D%21506&authkey=AJFGxs8eTZJxZyY" width="320" height="180" frameborder="0" scrolling="no"></iframe>
<iframe src="https://onedrive.live.com/embed?cid=0FA8FA1420D8254D&resid=FA8FA1420D8254D%21508&authkey=AC-90xQwH1eTr7w" width="320" height="180" frameborder="0" scrolling="no"></iframe>
<iframe src="https://onedrive.live.com/embed?cid=0FA8FA1420D8254D&resid=FA8FA1420D8254D%21510&authkey=AP_GE-5nzKLF2h4" width="320" height="180" frameborder="0" scrolling="no"></iframe>
Based on the SN, it's a '55. It came with a Dearborn back blade on it that I removed to clean up a bit before taking these photos. It runs well, but has several issues that fall somewhere between minor and severe - I don't know enough yet to say how serious/expensive it's problems are. I'll start topics specifically for each of these issues as I begin to attack them, but off the top of my head here's what needs work:
[b:c9b1ab21a4]Steering:[/b:c9b1ab21a4] The seller topped up the steering gear box (manual steering) before I took it home, noting that he might have overfilled it. It's leaking steadily - it looks like it's coming from the junction of the transmission case and the steering case, but there's enough oil in the area now it's hard to say for sure. There's a LOT of play in the steering, maybe a third of a revolution of the steering wheel before I feel resistance and the steering arms move. The steering column rises and falls maybe 3/16" when the wheel is turned in either direction between the points where it engages and begins turning the arms.
[b:c9b1ab21a4]Gauges:[/b:c9b1ab21a4] I doubt I can trust the oil pressure gauge. It runs around 40-50 lbs at all times (when the engine is running). I've run it for maybe 1.5 hours at a time, so I would have expected the gauge to drop as it warmed up. Seller changed the oil last fall when he took it in, putting in straight 30 weight. The proofmeter jiggles during operation but doesn't seem to move in response to RPM changes. The needle is broken off under the glass. Temp gauge and ammeter appear to be operating normally, but I'm not sure how to tell if the temp gauge is accurate.
[b:c9b1ab21a4]Leveling Box:[/b:c9b1ab21a4] Seems to be stripped or the gears are not engaging one another. When removed from the tractor and held upright with the gearbox at the top, turning the threaded shaft causes the crank to spin. When installed on the tractor the crank spins freely. I can feel the teeth rubbing but the shaft doesn't turn. Temporarily replaced with a TSC turnbuckle.
Lastly, I noticed after the last time I operated it that after shutdown I'm getting a small amount of dark, thin oil dripping from the front of the transmission case. Based on the way it's staining the cardboard it's parked over, I suspect there's water in it. This leak worries me more than the rest. I think the front-most section of the transmission case is supposed to be dry, but I'm just barely starting to learn about this stuff. Thoughts?
Anyway, I'm glad to be here and glad to have a new way to spend all of my disposable income
Brian
edit: As I suspected, my photos aren't showing up correctly. Clearly I'm doing something wrong... suggestions?
Brian
