LarryMaine
OK, all my hydraulics experience is with vintage Ford tractors in-built pumps for 3 pt hitch. I just bought a vintage 1960s front end loader for my Ford 850 with 4 cylinders. I am restoring it, i.e. Sandblast all, prime & paint, ALL new fittings and hoses, etc. As I am learning this new area I use the forum archives as much as possible, but I have some basic questions that I could use help with. Here they are. 1) there is no filter anywhere on the loader, am I better off putting an in-line filter on the return line or the suction line??? 2) the loader has the original Vickers Vane Pump model "V250 8 6D 12 949" "LH". I don't know the capacity of this pump. The oil resevouir is entirely within the frame of the loader I estimate only about 10 gallons, so I presume the pump is in the 5 to 8 gpm range. I want to buy a replacement pump. Should I look for a Vickers 20V Vane pump, or should I switch to a gear pump??? 3) Is a no load starting vane pump worth the great extra expense? 4) I have a Gresen 2 spool valve. I will give this to a professional to rebuild. But can someone tell me what is "Power Beyond" vs. "Closed Center". and what is "Load Check". and finally 5) My existing pump is stamped "LH". I presume this means left hand rotation. But in catalogues they only describe pumps now as CW clockwise or CCW counter clockwise rotation. Would my LH pump be equivalent to a CW or CCW pump??? Thanks all, I really do appreciate your time and effort in helping out a beginner like me. Larry
