Next 806 hydraulic system question....
Absent Minded Farmer
What's causing a slight surging sound on the MCV side of the system? Didn't hear it before the filter & valve change.
You can see that it effects the 3PT arms when you lift them. But you really have to stare at them to see the surging.
Is there any correlation between that & the draft control lever being seized?
Mike
Mike
I don’t know for sure , I’ve seen several tractors do that and usually moving the draft control will change it. Maybe a spring getting weak in one of the valves in the mcv or a slightly leaking o-ring. Never bothered me that much to tear all that apart over it
The MCV ( multiple control valve ) has nothing to do with the three point hitch. The surging in the hitch may have air in the system and should bleed itself out in time, depending on how often you use the hitch. If it continues you can always add a couple more gallons of fluid. The MCV controls the steering,TA,brakes,lube, and oil cooler. Draft control does not affect surging. Raise the hitch and lower it thru its full cycle with the position control lever several times after the oil is up to operating temperature. This will help bleed out the air. I’m curious, are you raising the hitch with an implement on it or empty. A load on the hitch is best for purging out air, if that is the issue. If it continues, try holding an auxiliary valve on demand and raise the hitch at the same time. If it helps than the unloading valve may be sticking
Glad you brought that up. No. I didn't operate the 3PT with a load on it & will do that tomorrow. Will a 540 plow be heavy enough or should I go with more weight?
Mike
Mike
If your starting to see a HIC UP on the three point normally it is caused by the piston seal on the rear hitch leaking or in the rear hitch valving . It also could be caused by some air getting into the system due to the filter cover not sealing due to the surface of the fliter cover at the bolt holes not being perfectly flat . Another point is the pick up tube in the rear end may have developed a hair line crack at the mounting point bracket . On this ya can dump five more gallon in and see if that stops the issue. To check that requires a lot of work pulling the rock shaft housing .
