Next chapter in the 300 saga
MoMike
Finally have the tractor split, found out the bearing in the flywheel exploded on me. Now, the bolts that hold the flywheel in place are they right or left hand thread? I'd hate to break one off by turning it the wrong way, don't need extra repair work. Thanks
You do not necessarily need to remove the flywheel to replace that pilot bearing. Only reason to remove the flywheel is if it needs resurfaced.
