Next item on 881
Can someone tell me the dimensions to locate the pin for stabilizing bars for the 3pt? I have a Paulson loader on the tractor and when my dad purchased the loader, the dealer removed the bracket for the stabilizer bars.
I really want to get one back on as it would make my 3pt blade work a lot better for grading driveway.
I am hoping to modify the loader mounting frame to accommodate the pin for the bar.
Thanks,
Brian
If no one comes up with it, I've got some new brackets on the shelf. I could likely measure the distance down and between the fender bolt holes.
I know I did what you're contemplating on a set of Ford loader hangers years ago.
I had a bracket around here but I don't know what happened to it. I didn't know it disappeared until I started looking for it for this issue. :?
(quoted from post at 16:29:10 03/11/17) It should be directly across and in line with the stud holding the lower lift arm.
That's correct. My stabilizer brackets have 4 (I think) holes in them so you can position the stub pins as close as possible to directly lining up with the lower lift arm pins.
What is the measurement from the center of fender bolt holes to the edge of the bracket the pin fastens to? If someone can let me know this measurement, I should be able to get it in the right spot on the loader bracket.
Brian
Got some measuring done for the stabilizer bar today. I think I can get the pin pretty close to where it needs to go on the loader bracket. I just hope I don't have to re-work too much of the bracket.
Brian
Got the pin put on loader bracket for the stabilizer bar today. Pretty easy, just had to drill a hole on one side of the loader frame and bolt it on once I got it located where to go.
Downside today is the fuel tank has a leak under the front mounting bracket. Didn't know it until I got all the other leaks fixed and filled tank 3/4 full of fuel.............
:x
Brian
