NH 270 Baler
Bramdad
2 problems
1) The needles do not return far enough to fully disengage the saftey resulting in sheer bolt failure (or success depending on perspective)
2) When the needles go all the way up they get hung up... to the point that the needle yoke rod bent. I removed the rod and the needles have to be hit to send them free.
Plunger timing is accurate
Thoughts?
a couple things to check. If like the bigger balers there is a needle stop adjustment, determines when needles are in home postion. Since you have to hit needles to get them to come up, possible the needle carrier bearings have an issue. Not sure if actual bearings or bushings wehre the carrier pivots on either side of the bale chamber. Also check to be sure needle carrier is not sprung or bent somewhere. with arm removed needles should remove freely on pivot points.
(quoted from post at 17:25:26 07/07/19) 2 problems
I had that problem on a couple of balers here in the past (NH 65 & NH 269) and a stretched chain was the problem. New chain with the exact number of links shown in the manual fixed that.
Yoke rod may be out of adjustment. Too long, perhaps??
Thoughts?
