MF in Canada
Hi folks,
I got a new-to-me baler and its working great, but it makes a loud banging sound when I turn to the right, even slightly.
Usually I am pretty good with things like this, but when I listened yesterday at low rpms with the tractor stationary, I could not identify which part was banging.
The sound is coming from the area just in front of the flywheel - there is a slip clutch, and over-running clutch and a U-joint in there.
The sound sounds like cast iron hitting cast iron - it's not a tinny shield type of sound.
It's not so bad turning left, and going straight ahead the sound disappears. It only takes a slight turn to the right to make the sound.
I would instantly suspect the U-joint, but the section of PTO shaft between the slip clutch and forward to the carrier bearing doesn't move around very much. All the articulation is taken by the two U-joints in the first short section of shaft before the carrier bearing.
Anyone have any thoughts or experience?
Greatly appreciated,
Eric
Eric
