If it's worn through on the flat that the bearings ride on, I had one that I cut out the bad part, welded a strip of metal on the outside for support, then welded a strip to fill in the part I cut out.
Smoothed things out with a small grinder.
Fred
I welded a steel bushing in mine for the shaft to pass through and mounted a pillow block bearing on the frame for the reel shaft.
Steve in se wis, I need the sheet metal that includes the hinged door and the wheel I talked about.Dave 319 642 3587.
